Siebel Order Management Guide > Creating a Quote or Sales Order > Common Tasks for Creating Quotes and Sales Orders >
Entering Payment Information for Quotes or Orders
End users enter billing and payment information in the Payments view tab of a quote or order. Siebel Order Management provides these payment methods: credit card, purchase order, check, money wire, cash, and stored value. Your company may add other payment methods through list-of-values administration. If you entered a payment profile for this customer, then when you make a selection in the Payment Method field, the Payment Detail form is automatically populated with the information that you entered in the profile for that payment method. The end user can edit this default information. For more information, see Creating Payment Profiles. This task is part of the Common Tasks for Creating Quotes and Sales Orders. To enter payment information
- Navigate to the quote or order for which you want to enter payment information.
- Click the Payments view tab.
- If payment terms are appropriate for this quote or order, then in the Payment Terms field, select the payment terms.
Your company's policies determine when payment terms must be used.
- In the Payment Lines list, below the Payment form, add a payment line item.
For the first payment line, the total amount of the order is copied into the Transaction Amount field.
NOTE: If this order was created from a quote that included payment information, then that information appears as a payment line item.
- If the customer will use more than one payment method, then change the amount in the Transaction Amount field to the amount for this first payment method.
- In the Payment Method field, select the method for the transaction amount.
The default payment method is Credit Card.
- In the Payment Detail form below the Payment Lines list, complete additional fields for the selected payment method.
- The form changes depending on the payment method selected. For details about important fields for each payment type, see Payment Fields for Payment Methods.
- For credit card and purchase order payments, check the customer's credit.
- For a purchase order payment, click Credit Check.
- For a credit card payment, click Authorize.
NOTE: For sales orders, you will typically use Authorize before placing the order. Then later, after the order has been filled, you may return and click Settle. When creating field service orders or cash and carry orders, you may want to use Authorize and Settle instead of Authorize at the time of order.
- Review the Payment Status field and select a status, if appropriate.
You may return to change this field later, for example, after receipt of a check. For details about changing the payment status, see Changing the Status of a Payment.
- For each additional payment method, repeat Step 4 through Step 10. When you add another payment method, the transaction amount will default to the remaining amount not yet associated with a payment method.
Each payment method requires different information. When an end user adds a payment method to an order, the Payment Details form below the Payment Lines list shows the appropriate fields for that payment method. The available buttons on the form also change, to reflect the appropriate actions for that payment type. For example, a cash payment does not need to be authorized or settled, while a credit card payment does. The following tables list important payment detail fields for each of the payment methods.
Table 26 lists important payment detail fields for checks.
Table 26. Payment Detail Fields for Checks
Transaction Amount |
Amount for the individual payment transaction. |
Payment Method |
Check |
Payment Type |
Type of check being used: Personal, Corporate, or Cashiers. |
Check Number |
The identifying check number. |
Date of Birth |
The customer's date of birth. |
Checking Account Number |
The bank account number for the check. |
ABA Code |
The American Banking Association code for the bank on the check. |
Social Security # |
The customer's social security number. |
Drivers License State |
The state in which the customer has a driver's license. |
Drivers License # |
The customer's driver's license number. |
Bill To Account Name and Address |
Name and address of the account being billed for this payment line item. Defaults from the Payment form. |
Authorization Code |
Code indicating that authorization of the check has been given. |
Authorization Date |
Date authorization was given for the check. Can be entered manually or configured to be entered automatically. |
Check Mailing Address |
Your company's mailing address, to tell the customer where to mail the check. |
Payment Status |
Defaults to Pending Receipt of Check Receipt. Change this value after the check has been received and deposited, and funds received. |
Table 27 lists important payment detail fields for credit cards.
Table 27. Payment Detail Fields for Credit Cards
Payment Method |
Credit Card |
Payment Type |
The type of credit card. Out-of-the-box, available types are Visa, MasterCard, Discover, and American Express. |
Credit Card # |
The credit card number. |
Expiration Month |
The month the credit card expires. |
Expiration Year |
The year the credit card expires. |
Issuing Bank |
The name of the bank that issued the card. |
Issuing Bank Phone Number |
The phone number for the bank that issued the card. |
Credit Card Holder |
Name of the person on the credit card. |
Billing Address, City, State, Zip |
Address fields for the person responsible for this payment line item. Defaults to the account's bill-to address. |
Payment Status |
After you click Authorize or Authorize and Settle, the credit card authorization process returns one of the following values as the status:
- Authorized. Indicates the credit card payment for the transaction amount entered has been approved.
- AVS Failed. Indicates that the address entered for the customer did not match the address in the Address Verification System (AVS).
- Card Verification Declined. Indicates this payment was declined because the card could not be verified.
- Charged. Indicates the charge was authorized and has been charged.
- Declined. Indicates authorization was declined.
- Need Verbal Authorization. Indicates that the bank must call the owner of the card for authorization.
- Referral. Neither approved nor declined. The bank needs to research something related to authorizing this payment.
Code returned when the transaction was authorized. |
Date the transaction was authorized. |
AVS Code |
Code provided by the Address Verification System (AVS) to indicate the address for the credit card was verified. |
Customer Code |
For a corporate customer, a code verifying that the credit card may be used. |
Card Verification # |
This field contains a four digit unique identifier that is often printed on the back of a credit card. It is used to reduce fraud because only the person holding the card must know it. This field must be deleted after the number is submitted for authorization. |
Merchant ID |
Your company's identifying number. If more than one Merchant ID is available, then the correct ID for this payment can be selected from list. |
Table 28 lists important payment detail fields for purchase orders.
Table 28. Payment Detail Fields for Purchase Orders
Payment Method |
Purchase Order |
Purchase Order # |
Number of the purchase order. May display Pending if the order was created from a quote which had Pending as the PO#. |
Payment Type |
For a purchase order, the payment type is Payment. |
Payment Status |
Status of the payment. Defaults to Pending Check Receipt. Change this value after the funds have been received. |
Credit Status |
Status information returned from the back office after a credit check is done by clicking Check Credit. |
Credit Status As Of |
Date the credit check status information was returned. |
Credit Check Message |
Message text returned with the credit status. |
Bill To Account |
Name of the account responsible for this payment line item. |
Bill To Address |
Address of the account to be used in relation to this payment line item. |
Approval Date |
Date that the purchase order payment was approved. |
Approved By |
The name of the person who authorized the purchase order. |
Code returned when the payment was authorized. |
Date the payment was authorized. Can be the date the funds appear in the account. |
Payment Comments |
Any comments appropriate for this payment. |
Table 29 lists important payment detail fields for wire transfers.
Table 29. Payment Detail Fields for Wire Transfers
Payment Method |
Wire Transfer |
Originating Bank |
The bank sending the transfer. |
Branch Bank Address, City, State, Zip |
The address of the bank sending the transfer of funds. |
Bank Routing # |
Routing number for the bank. |
Payment Account # |
Wire transfer account number. |
Date of birth |
Bill To Account Name |
Contact Name |
Person to contact in relation to this payment line item. |
Contact Phone |
Phone number for the contact. |
ABA Code |
Social Security # |
Date the payment was authorized. May be the date you see the funds in the account. |
Payment Status |
Status of the payment. Defaults to Pending Check Receipt. |
Drivers License # |
The state in which the customer is licensed to drive. |
Table 30 lists important payment detail fields for stored values.
Table 30. Payment Detail Fields for Stored Value
Payment Method |
Stored Value |
Payment Type |
Type of stored value. Preconfigured values are Gift Certificate and In-Store Credit |
Payment Status |
Contact Name |
Contact name associated with the stored value. |
Payment Account # |
Number of the account that will provide the payment of the stored value. |
Account Name |
Name of the account with which the payment is associated. Defaults to the bill-to account. |
Approving a Payment
Depending on how your company has set up payments, certain payment methods might require approvals before they can be accepted. The initial payment status is set to pending. A user with approval capabilities will then need to change the status to approved. NOTE: Approving a payment is not the same as authorizing a payment. Authorization performs a credit check through a back-office application.
To approve a payment
- Navigate to the quote or order for which payment needs to be approved.
- Click the Payment view tab.
- In the Payment Lines list, select the purchase order payment to approve.
- In the Payment Detail form, below the Payment Lines list, enter your name in the Approved By field and enter today's date in the Approval Date field.
The status assigned to a payment may be set automatically in some cases (such as when a credit card is authorized), but needs to be set manually in others. For example, when the payment method is a check, the initial status is set to Pending Check Receipt. After a company receives funds for the check, an end user can manually change the status of the payment transaction to Authorized, for example. Your company may also create business processes that automatically update the status under certain circumstances. Table 31 lists the possible payment statuses and explains when they are likely to be used.
Table 31. Payment Statuses
New |
Payment information was sent, but confirmation of receipt from the back-office application was not received. The message may not have been received. |
Authorized |
The payment has been authorized. |
Declined |
The payment has been declined. |
Charged |
The payment has been charged to a credit card. |
Refunded |
The payment has been refunded to the customer. |
Reversed |
The payment shown was previously charged to a credit card, and that charge has been reversed; a credit for the same amount was sent to the credit card. |
Referral |
Payment has been held by the bank until the bank can gather additional information. |
Pending Check Receipt |
A check, purchase order, or wire transfer has been received. Receipt of the payment has not yet occurred. |
AVS Failed |
Indicates that the address entered for the customer did not match the address in the Address Verification System (AVS). Typically used with credit card payments |
Card Verification Declined |
A third-party authorization application was not able to verify the credit card. |
Need Verbal Authorization |
This payment needs to be verbally authorized by the credit card company. |
To change the status of a payment
- Navigate to the quote or order for which the payment status needs to be changed.
- In the Payment Lines list, select the appropriate status in the Payment Status field.
Checking Credit for a Purchase Order
An end user can check a customer's credit when the payment method is a purchase order. The end user can also check credit when payment is made using a credit card. For information, see Authorizing and Settling Credit Card Payments. To check credit for a purchase order
- Navigate to the quote or order which you are working.
- If necessary, enter the purchase order information.
- In the Payment form, click Credit Check.
Your Siebel Business Application sends an authorization request to your back office or financial application to confirm whether the purchase order is valid and the payment can be authorized.
The back-office application returns information to three fields: Credit Status, Credit Status As Of, and Credit Check Message.
In an order, an end user can check authorization of payment by credit card and can then settle the payment, to collect the amount authorized. For credit card authorization to be available, your Siebel Business Application must have implemented integration with another payment processor. For more information, see Siebel eSales Administration Guide. To authorize and settle a credit card payment
- Navigate to the quote or order with which you are working.
- If necessary, add a Payment Line and enter the credit card payment information, or select the payment line containing the credit card payment.
- Perform one of the following:
NOTE: When the end user clicks Authorize or Authorize and Settle, credit check calls a payment processing application to approve the transaction. Sometimes an error is returned, or the payment is rejected, and the end user can use the status and any error message returned to determine the appropriate course of action.
Authorizing a Credit Card Payment Manually
When the credit check of a credit card payment returns the Payment status Declined or Referred, the end user will need to assess the reason the payment has not been approved. If the end user determines that the payment is good, then he or she can manually authorize the payment. In such a case, the end user must obtain an authorization code verbally from the credit card company. To manually authorize a credit card payment
- Navigate to the order with which you want to work.
- Click the Payments view tab and select the credit card payment line with the Payment Status of Declined or Referred.
- In the Authorization Code field, enter the authorization code.
- When you are prompted to confirm the change to the order, click Yes.
Your Siebel Business Application accepts the new entry and the credit status on the line item is changed to Authorized. A note appears in the Payment History with the change request date and requestor. This manually entered code is used to validate the order approval with the bank during settlement processes.
Checking Payment History
It is important to be able to explain to customers all of the transactions that relate to their payment method. An end user can see all transactions against a specific payment line by checking the payment history. For example, if a credit card is authorized manually, then that action is noted in the history, along with the date and requestor. The specific changes that are recorded in the payment history are determined by settings your company makes in the Application Administration screen, Audit Trail view. For complete information about setting up Audit Trail, see Siebel Applications Administration Guide. To check payment history
- Navigate to the order for which you want to check payment history.
- In the Payment Lines list, below the Payments form, select the payment for which you want to see history information.
- From the menu of the Payment Lines list, select Payment History.
The Payment History dialog box appears, listing information about changes to the payment item.
Entering Refunds
An end user can enter a refund of a credit card payment for a customer, when appropriate. Refunds are given after a settlement of a payment has occurred and funds have been transferred. To enter a refund
- Navigate to the order for which you want to enter a refund.
- In the Payment Lines list, below the Payments form, select the credit card payment for which you want to enter a refund, and click Refund.
