Siebel Order Management Guide > Creating a Quote or Sales Order > Process of Enabling the Automatic Configuration of Customizable Products >
Headless Configuration Service
The Headless Configuration business service is required to enable the automatic configuration of customizable products that are based on a promotion definition. It works with or without the user interface. It contains the following public methods
Table 35 describes the Headless Configuration service user properties that you must set. ApplyPromotionDefaults Method
This method is automatically triggered by the Siebel Business Application when you apply a promotion, provided the Promotion Automatch system preference is set to Y. This method is not triggered if the Promotion Automatch system preference is set to N, or if the Promotion Automatch system preference is not defined. This method configures customizable product line items in the current product as follows:
- It loads the product line item.
- Runs batch validation on the product line item.
- Changes the product line item according to the Promotion Automatch argument value.
Table 32 describes Siebel CRM behavior when the Promotion Automatch argument value is set to Default Cardinality, and when the Promotion Automatch argument value is set to Min Max Cardinality. For more information about cardinality, see About Cardinality.
- It writes the line item back to the document
This method does not require a user interface context to be called, and contains the method arguments listed in Table 32. In asset-based ordering (ABO) mode, ApplyPromotionDefaults calls the SIS OM Get Future Asset subprocess workflow, which computes the action codes. About Cardinality
Cardinality refers to the quantity of the component that a user can select. Minimum cardinality governs whether or not selecting items from a relationship is optional or required. Maximum cardinality sets the maximum number of items that a user can select from a relationship. Default cardinality specifies what quantity of the default product is automatically added to the initial solution that the user sees. For more information about cardinality, see Siebel Product Administration Guide.
Table 32. ApplyPromotionDefaults Method Arguments
Promotion Automatch |
String |
Input |
If set to Default Cardinality, then Siebel CRM behavior is as follows:
- Non-existing items change to the default quantity.
- Existing ports below the minimum quantity change to the default quantity.
- Existing ports above the maximum quantity change to the default quantity.
- Existing product ports not violating the cardinality remain the same.
- Existing class ports below the default quantity change to the default quantity.
If set to Min Max Cardinality, then Siebel CRM behavior is as follows:
If set to blank (if no value is set), then Siebel CRM behavior reverts to the existing behavior (that is, the behavior in previous versions of Siebel Order Management). The default setting is blank. |
Log Error |
String |
Input |
If set to Y, then logs error messages. The default is Y. |
Display Error |
String |
Input |
If set to Y, then displays Unified Messaging Framework (UMF) messages; a user interface context is required. If, depending on application of the promotion, the customizable product structure changes, then the UMF message displays the recommendations applet in the dynamic catalog view; or, the user can open the recommendations applet using the recommendation icon. The default is N. |
Document Id |
String |
Input |
The Header Id of the quote or order. |
Document Type |
String |
Input |
This value must be either Quote or Order. |
Integration Object |
String |
Input |
Depending on document type and ABO mode, this argument defaults to either one of the following:
- SIS OM Order, or SIS OM Quote
- When ABO is turned off: 7.7 Order Entry Integration Object, or 7.7 Quote Integration Object
Search Spec |
String |
Input |
The Search Spec is applied to the business component line item. By default, this argument is empty. However when ApplyPromotionDefaults is called automatically on applying a promotion (by setting the Promotion Automatch system preference to Y), this argument is set by the application to retain only those line items that are associated with that promotion instance. See also the following related Search Spec user properties in Table 35:
- Order Default Search Spec
- Quote Default Search Spec
Sync |
String |
Input |
If set to Y, then the result is synchronized to the database. The default is N. |
Restore Document Method
This method restores the document to its saved state, and contains the method arguments listed in Table 33. If an error is encountered during execution of the ApplyPromotionDefaults method, then Restore Document is automatically triggered by the application (provided the Promotion Automatch system preference is set to Y). Restore Document is not triggered if the Promotion Automatch system preference is set to N, or if the Promotion Automatch system preference is not defined.
Table 33. Restore Document Method Arguments
Document Id |
String |
Input |
Document Type |
String |
Input |
Document Type must be either Quote or Order. |
Save Document Method
This method saves the document in its current state, and contains the method arguments listed in Table 34. This method is automatically triggered by the application to save the state of the document before applying the promotion, provided that the Promotion Automatch system preference is set to Y. This method is not triggered if the Promotion Automatch system preference is set to N, or if the Promotion Automatch system preference is not defined.
Table 34. Save Document Method Arguments
Document Id |
String |
Input |
Document Type |
String |
Input |
Headless Configuration Service User Properties
Use the Headless Configuration service user properties to set the values given in Table 35.
Table 35. Headless Configuration Service User Properties
Business Service User Property |
Logging Level |
3 NOTE: This value is the threshold log level for error messages.
Order Business Object |
Order Entry (Sales) |
Order Default Search Spec |
[IsComplexProductRoot]='Y' AND [Action Code] <> LookupValue('DELTA_ACTION_CODE','Deleted')
NOTE: The search specification is appended to the input argument Search Spec.
Order Due Date Field |
Requested Ship Date |
Order Header Business Component |
Order Entry - Orders |
Order Line Item Business Component |
Order Entry - Line Items |
Quote Business Object |
Quote |
Quote Default Search Spec |
[IsComplexProductRoot]='Y' AND [Action Code] <> LookUpValue('DELTA_ACTION_CODE','Deleted')
Quote Due Date Field |
Due Date |
Quote Header Business Component |
Quote |
Quote Line Item Business Component |
Quote Item |
UMF Headless Configuration Messages Source |
Headless Configuration |
UMF Headless Configuration Error Messages Score |
100 NOTE: The UMF message is displayed whenever an apply promotion is undone.
UMF Headless Configuration Error Messages Type |
Headless Configuration Error Message NOTE: The UMF message is displayed whenever an apply promotion is undone.
Headless Configuration Proceed Message NOTE: The UMF message is displayed when changes are made to the customizable product using ApplyPromotionDefaults.
UMF Headless Configuration Messages Score |
30 NOTE: The UMF message is displayed when changes are made to the customizable product using ApplyPromotionDefaults.
UMF Headless Configuration Messages Type |
Headless Configuration Message |
