Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Requiring User Registration for Availability to PromiseSiebel eSales does not require the customer to register on the Web site before checking product availability. However, you can configure the logic behind the Check Availability button to require registration by:
This task applies to customers checking product availability using Siebel eSales. It does not apply to employees checking product availability. This task is a step in Process of Setting Up Third-Party Product Availability Applications. To hide the Check Availability button
To add the Explicit Login parameter to the ATP Fulfillment View (eSales)
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
