Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability ApplicationsTo set up the use of third-party product availability-to-promise applications, you must perform the following tasks:
When setting up the use of third-party product availability-to-promise applications, you can perform the following optional tasks:
When setting up the use of third-party product availability-to-promise applications, you can perform the following optional task that applies only to Siebel eSales: For more information about how to set up, use, and modify integrations according ASIs, see Siebel Application Services Interface Reference. For information about the employee end user's experience in using the availability-to-promise features, see Checking Availability to Promise (ATP). |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
