Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Checking Availability Fulfillment MethodsFor the integration to work, you must check that your ATP engine supports the Inquire, Reserve, and Unreserve methods. If your ATP engine refers to these methods with different terms, then you may need to do some configuration to map the method names. For customers to check availability using Siebel eSales, you must find a method that is supported by your ATP engine and that checks availability without reserving it. The Inquire method is one possible example. You may want to check other supported methods, such as Reserve and Unreserve, to see how you can extend your availability checking function. This task is a step in Process of Setting Up Third-Party Product Availability Applications. |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
