Siebel Order Management Guide > Integrating Order Management with Third-Party Product Availability Applications > Process of Setting Up Third-Party Product Availability Applications > Preventing Rollup of Availability Summary DataProduct availability information is displayed for: The following information is preconfigured to roll up:
If your availability fulfillment engine only returns promised schedule lines and does not roll up this data to the line or the header, then the preconfigured behavior will provide you with a rollup of the data. However, if your fulfillment engine already calculates this rollup, or if you do not want to roll up these fields, then you may want to turn off this behavior. Following are some examples of the preconfigured rollup of availability information:
NOTE: Rollup only occurs on quantity and date when the status of the promised line or the status of the line item is Available or Reserved. This task is a step in Process of Setting Up Third-Party Product Availability Applications. |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
