Siebel Order Management Guide > Integrating Order Management with Third-Party Credit-Check Applications > Process of Setting Up Purchase Order Credit Checking Applications > Extending the ASI for Credit Check Interface RequestIf you want to extend the ASI, then you must add fields to: This will create the necessary mapping between the Credit Check interface structure and the Siebel Quote and Order business components. If you add a field, then make sure that the names of the fields in the Internal and External integration objects match. For example, if you want to add the field Priority that maps on quote to Priority-quote and on order to Priority-order, then you would set up the names as indicated in Table 11.
For information about how to extend the integration object, see Integration Platform Technologies: Siebel Enterprise Application Integration. This task is a step in Process of Setting Up Purchase Order Credit Checking Applications. |
| Siebel Order Management Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
