Siebel Order Management Guide Addendum for Communications > Workflows for Customer Asset-Based Ordering > Workflow That Ungroups Quotes > CUT eSales - Ungroup Quote WorkflowThis workflow decomposes all or some line items into multiple instances with a quantity of one when the original quantity is greater than one. This workflow decomposes the root item for the selected item and all the children for this root item into multiple instances. If the user selects some line items and clicks the Ungroup button, then FrameEventMethodUgroupSelected is called to ungroup only the selected line items. If the user selects no line items and clicks the Ungroup button, then FrameEventMethodUngroupAll is called to ungroup all the line items. Figure 180 shows both variations of this workflow. NOTE: If you use the variation to ungroup all items, then you must change the configuration by removing the select item column from the shopping cart. The user initiates this workflow by clicking the Ungroup button in the Shopping Cart view. Workflow Description. This workflow performs the following actions:
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
