Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Bulk Request Processing >
About Exploding an Action Set Template
When you click the Explode button in the Action Set Template view, then depending on the records in the attached list, the action value in the Type field, and the value in the List Content field, Explode performs the actions described in this topic.
Explode Action for a List of Accounts
When you attach a list of accounts, Explode performs the actions described in Table 18.
Table 18. Effects of Exploding an Accounts List
Action Type
Explode Actions
New
Creates an action set for each account in the list. Associates the actions specified in the Action Set Template view, Actions list with each action set.
Modify
For each account that has a product defined in the Action Set Template view, Actions list, creates a Modify action set. Associates the instances in the list with action sets. Associates the actions defined in the template with the action sets.
Upgrade
For each account that has a product defined in the Action Set Template view, Actions list, creates an Upgrade action set. Associates the instances with the action sets. Associates the actions defined in the template with the action sets.
Explode Action for a List of Contacts
When you attach a list of contacts, Explode performs the actions described in Table 19.
Table 19. Effects of Exploding a Contacts List
Action Type
Explode Actions
New
Creates one Add action set for each distinct account associated with one or more of the contacts in the list. Associates the actions specified in the Action Set Template view, Actions list with each action set. Adds the contacts specific to each account in the Instances list.
Modify
Creates one Modify action set for each distinct account associated with one or more of the contacts in the list. Associates the actions specified in the Action Set Template view, Actions list with each action set. Adds the contacts specific to each account in the Instances list.
Upgrade
Creates one Upgrade action set for each distinct account associated with one or more of the contacts in the list. Associates the actions specified in the Action Set Template view, Actions list with each action set. Adds the contacts specific to each account in the Instances list.
Explode Action for a List of Assets
When you attach a list of assets, Explode performs the actions described in Table 20.
Table 20. Effects of Exploding an Assets List
Action Type
Explode Actions
New
Not a valid combination.
Modify
Creates an action set for each owner account on the asset. Associates instances (assets) with the action sets. Associates the actions specified in the Action Set Template view, Actions list with each action set.
Upgrade
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
