Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Process of Configuring Prepaid Services >
Configuring Virtual Business Components
After the administrator creates the proxy business services, the administrator enters the data in these proxy business services into the virtual business components that retrieve and display data from the billing application. For information about creating proxy business services, see Creating Outbound Web Services.
The administrator configures the following virtual business components:
  • Prepaid Service - All Activities
  • Prepaid Service - Current Balance
  • Prepaid Service - Top Up Request
  • Prepaid Service - Top Up Request Popup
  • Prepaid Service - Top Up Request (Assets)
This task is a step in Process of Configuring Prepaid Services.
To configure the virtual business components
  1. Log in to Siebel Tools as an administrator.
  2. For each proxy business service that you create:
    1. In the Object Explorer, navigate to Business Service, select the proxy business service, and note the name for the proxy business service.
    2. In the Object Explorer, navigate to Business Service, then Business Service Method, and note the method name for the proxy business service.
    3. In the Object Explorer, navigate to Business Service, then Business Service Method, then Business Service Method Arg, and note the name of the input and output argument for the method for the proxy business service.
      The input and output arguments have a value of Integration Object in the Data Type field. The input argument name is the request type, and the output argument name is the response type.
  3. For each Prepaid Service virtual business component:
    1. In Object Explorer, navigate to Business Component, select a Prepaid Service virtual business component.
    2. Lock the business component so that you can change it.
    3. In Object Explorer, navigate to Business Component, then Business Component User Prop, and configure the following user properties:
      • For the Proxy BS Name user property and the Proxy BS Name: Validate user property, enter in the Value field the business service name that you noted in Step 2.
      • For the Proxy BS Method user property and the Proxy BS Method: Validate user property, enter in the Value field the method name that you noted in Step 2.
      • For the Proxy BS Param: Request Message Type user property and the Proxy BS Param: Request Message Type: Validate user property, enter in the Value field the input argument name that you noted in Step 2.
      • For the Proxy BS Param: Response Message Type user property and the Proxy BS Param: Response Message Type: Validate user property, enter in the Value field the output argument name that you noted in Step 2.
    4. Compile the Prepaid Service virtual business components for your changes into the Siebel Repository File, Siebel_sia.srf.
    5. Unlock the business component.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
