Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Defining Promotion Merge >
Example of Defining a Promotion Merge
This topic gives one example of how merged promotions might be used. You might use merged promotions differently, depending on your business model. In this scenario a product administrator wants to offer customers bundled promotions at a discount. The administrator merges three promotions: Wireless Bundle, Broadband Offer, and IPTV Offer into the Triple Play Offer promotion that includes Wireless, Broadband, and IPTV. Figure 16 illustrates the merging of these promotions.
Figure 16. Merged Promotion
The merger of promotions shown in Figure 16 uses the following logic:
- Merge Promotion 1 to n to Promotion A.
- Disconnect Promotion 1.
- Disconnect Promotion n.
- Apply Promotion A.
Commitment must be included in the merge definition. To define a promotion merge
- Navigate to Administration - Product, Product Promotions, then Merge.
- In the Merge list, click New.
- Enter a name for this scenario, for example, Family Plan Bundle.
- Enter a description.
NOTE: If the Track As Agreement flag for the promotion is checked, then the use of Aggregate Commitment Start and Aggregate Duration are related to the creation of agreement for the new promotion.
- In the Aggregate Commitment Start field, select a time to start this merged promotion.
The start date for any agreement item of the new promotion, that is, the promotion into which it is merged, is determined by the value in the Aggregate Commitment Start field:
- Earliest Start. Starts on the earliest date among all the start dates of the original promotions from which they are merged.
- Earliest End. Ends on the earliest date among all the end dates of the original promotions from which they are merged.
- Latest Start. Starts on the latest date among all the start dates of the original promotions from which they are merged.
- Latest End. Ends on the latest date among all the end dates of the original promotions from which they are merged.
- In the Aggregate Duration field, choose a duration to run this merged promotion.
The duration for any agreement item of the new promotion, to which it is merged, is determined by the value in the Aggregate Duration field:
- In the Component list below the Merge list, click New and select a promotion in the Promotion field.
- In the Min and Max fields, enter the minimum cardinality and maximum cardinality.
- In the Penalty field, enter an amount, in currency, to charge if the customer cancels the promotion before its designated end.
You can change the national currency and date of exchange rate in the dialog box.
- Select a Prorate Plan.
Prorate plans are defined in the Administration screen, Contracts, and then the Conditional Charge Plans view. For more information about prorated plans, see the topic on setting up conditional charge plans in Siebel Field Service Guide.
- To activate, do the following:
- Navigate to Administration - Application, then System Preferences.
- Set All Assets to Y or Yes.
Customers can selectively activate or deactivate this behavior in specific scenarios (for example, to modify or upgrade, and so on) by toggling the value of All Assets in the workflow steps used in that particular scenario. By default, the value of the All Assets system preference is passed to each workflow step.
