Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Promotion Transitions Ambiguity Resolution > Controlling Promotion Ambiguity ResolutionEvery product promotion has a check box that allows administrators to determine whether ambiguity resolution will be manual or automatic. Depending on the case, the expected behavior is as follows:
Defining Automatic Promotion Ambiguity ResolutionThis topic describes how to define automatic promotion ambiguity resolution for a promotion product. To define automatic promotion ambiguity resolution for a promotion product
Defining Manual Promotion Ambiguity ResolutionThis topic describes how to define manual promotion ambiguity resolution for a promotion product. To define manual promotion ambiguity resolution for a promotion product |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
