Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > About Promotion Transitions Ambiguity Resolution > About Manually Resolving Ambiguous Promotion TransitionsAny promotion transition in which there are several possible outcomes for one or more components can cause an ambiguity. Ambiguity can occur during the following flows: Ambiguity is caused by the following promotion definition cases:
When an ambiguity occurs during a promotion transition for which the administrator has enabled manual promotion ambiguity resolution, the user is presented with a dialog box to resolve the ambiguity. The dialog box displays a list of ambiguous component instances and a target promotion definition. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
