Siebel Order Management Guide Addendum for Communications > Employee Asset-Based Ordering > Modifying the Order Priority MappingWhen an order is submitted, the message posted to the Java Message Service (JMS) queue includes the order priority that a user selects in Siebel CRM. A mapping of this order priority selection to a language-independent code recognized by JMS allows the order to be processed through the JMS queue according to the priority specified in Siebel CRM. You must change the default order priority mapping from Siebel CRM to JMS, as described in this topic. To change the order priority mapping from Siebel CRM to JMS, follow this procedure. To modify the order priority mapping
For more information about configuring lists of values, see the chapter on working with lists of values in Siebel Applications Administration Guide. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
