Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflows for Ambiguity Resolution >
ISS Promotion Collect Eligible List Workflow
This workflow uses the list of promotions that are disconnected during a promotion transition to collect a list of assets that are eligible for the promotion transition.
This workflow is called by the following workflows:
  • ISS Promotion Upgrade Process
  • ISS Promotion Merge SubProcess
  • ISS Promotion Split Process
Figure 124 illustrates this workflow.
Figure 124. ISS Promotion Collect Eligible List Workflow
Workflow Description. This workflow performs the following actions:
  1. Is Merge Flow. This step determines whether this workflow is triggered from an activity for promotion merging.
  2. Set Last Record. This step sets last record to a value of True for an activity that is not for promotion merging. Only one promotion instance exists from which related assets must be retrieved.
  3. Get Next Prom Inst. This step gets the promotion instance for which related assets must be retrieved for an activity that is for promotion merging.
  4. Collect Asset for Prom Inst. This step collects all of the related assets for the promotion instance.
  5. Filter List By Active Doc. This step filters the list by using the active document.
  6. Append to Asset List. This step appends the assets to output list.
  7. All Promo Done? This step determines whether more promotion instances must be processed.
  8. Get Asset Details. This step gets the asset information for the collected list of assets when no more promotion instances must be processed.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
