Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflow for User Prompts >
ISS Promotion Prompt Interactive Sub Process Workflow
This workflow displays an interactive view in which users can select an action for the debundled products of a promotion. Users can select an action only for components that include Prompt in the promotion definition. After users select actions and click the Done button, the selected actions are applied to the components in the resulting quote or order.
This workflow is called by the ISS Promotion Disconnect Process workflow.
Figure 127 illustrates this workflow.
Figure 127. ISS Promotion Prompt Interactive Sub Process Workflow
Workflow Description. This workflow performs the following actions:
  1. Set Active BC. This step sets the active business component for this workflow to Asset Mgmt - Asset (Order Mgmt).
  2. Store Related List. This step stores the input lists in the ISS Promotion Management Service business service class.
  3. Check Prompt Screen Necessity. This step checks to determine whether the prompt screen applies.
  4. Is Prompt Screen Needed? This step goes to Step 5 when the prompt screen applies.
  5. Go to User Prompt view. This step displays the user prompt view.
    The Proceed Decision connector generates to the InvokeMethod event when the user clicks the Done button. It invokes the EventMethodDone method on the virtual business component.
  6. Proceed.Decision (Connector). This step generates to the InvokeMethod event when 'Done' button is clicked. It invokes 'EventMethodDone' method on the VBC.
  7. Get Clicked Button. This step gets the button that the user clicks.
  8. Continue? This step evaluates the clicked button.
  9. Cancel Workflow. This step cancels the workflow when the user clicks the Cancel button.
  10. Get Stored List. This step stores the processed modified list in the output when the user clicks the Done button.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
