Table 105. Workflows to Process Promotions
ISS Promotion Calculate Component Penalty Charges SubProcess |
This workflow calculates the penalty charges for disconnecting a promotion component, and cumulates the charge amounts of all the sub-objects. This workflow is called by the ISS Promotion Calculate Related Objects Penalty Charges SubProcess workflow. |
ISS Promotion Calculate Related Objects Penalty Charges SubProcess |
This workflow calculates the penalty charges for all the related components of a promotion, and cumulates the charge amounts. This workflow is called by the ISS Promotion Calculate Promotion Penalty Charges SubProcess workflow. |
ISS Promotion Disconnect Process |
This workflow disconnects a promotion, and considers component-level commitments and penalty charges. This workflow is called by the ISS Promotion Group Membership Disconnect Process workflow. |
ISS Promotion Disconnect Component SubProcess |
This workflow disconnects a promotion component with a commitment. A user can accept or reject the penalty. This workflow is called when promotion components are disconnected. |
ISS Promotion Disconnect Integration SubProcess |
This workflow considers component-level commitments and penalty charges. This workflow is called when promotions or promotion components are disconnected. |
ISS Promotion Upgrade Process |
This workflow upgrades existing promotions to new promotions. This workflow is called when a user selects Upgrade Promotion in the menu for the Installed Assets applet. |
ISS Promotion Upgrade Charge Proration SubProcess |
This workflow calls a sub-process that runs the FS Conditional Charge business service to calculate the penalty from certain inputs. You can replace the workflow content with your own content (for example, a Web service call to external calculation engines), if you provide the same output arguments. This workflow is called by the ISS Promotion Upgrade Check Agreement SubProcess and by code in the promotion business service. |
ISS Promotion Upgrade Check Agreement SubProcess |
This workflow calculates any prorated penalty for disconnecting an existing promotion and displays the value on the Upgrade Promotion pop-up applet. This workflow is called in the Upgrade Promotion pop-up applet when a user selects Upgrade Promotion in the menu for the Installed Assets applet. |
ISS Promotion Debundle Integration SubProcess |
This workflow provides the list of promotion components to debundle. This workflow is called when a user selects De-bundle Promotion in the menu for the Installed Assets applet. |
ISS Promotion Debundle Process |
This workflow debundles the list of assets that the user selects for debundling. This workflow is called when a user selects De-bundle Promotion in the menu for the Installed Assets applet. |
ISS Promotion Recommendation For Assets |
This workflow handles promotion recommendations through installed assets and applies the promotion when the user accepts a promotion recommendation. This workflow is called when a user selects Recommendations in the menu for the Installed Assets applet. |
ISS Add To Promotion Sub Process |
This workflow provides the list of promotion assets in the Add to Promotion pop-up applet. This workflow is called when a user selects Add to Promotion in the menu for the Installed Assets applet. |
ISS Promotion Add To Promotion Process |
This workflow applies the promotion selected in the Add to Promotion pop-up applet and brings the promotion and its related assets to the active document. This workflow is called when a user clicks OK in the Add to Promotion pop-up applet. |
ISS Promotion Commitment Compliance Check SubProcess |
This workflow considers promotion components from other service accounts. This workflow is called when a document is checked for promotion commitment violations. |
ISS Promotion Disconnect Process - for Verify |
This workflow considers promotions from other service accounts. This workflow is called when a promotion is disconnected, and the user accepts a penalty charge when verifying a document with a promotion violation. |
ISS Promotion Merge SubProcess |
This workflow is called by the ISS Promotion Merge Process workflow and through the Rebundle Options menu item when the option selected is Merge. |
ISS Promotion Merge Process |
This workflow merges the multiple promotions selected in the Installed Assets applet into the target promotion, as specified in the promotion merge definition. This workflow is called when a user selects Merge Promotion in the menu for the Installed Assets applet. |
ISS Promotion Split Process |
This workflow splits a promotion selected in the Installed Assets applet into multiple promotions, as specified in the promotion split definition. This workflow is called when a user selects Split Promotion in the menu for the Installed Assets applet. |
ISS Promotion Verify SubProcess |
This workflow considers promotion components from other service accounts to verify a document. For more information about this workflow, see ISS Promotion Verify SubProcess Workflow. This workflow is called when a document is verified. |
