Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflows to Validate a Network >
VORD Validate (Quote) Workflow
This workflow validates the network (or compound product) associated with the currently selected quote line item. It executes the rules associate with the Compound Product and reports any violations. This workflow is initiated when a user clicks the Validate button on the Network Line Detail applet in the Quote screen, Line Item, and then the Network Line Detail View. This workflow is shown in Figure 40.
Figure 40. VORD Validate (Quote) Workflow
Workflow Description. This workflow performs the following actions:
- Quote Converted to Order? This step checks whether the quote has already been converted to an order. If so, then this step displays an error message and terminates the workflow.
- Future Date. This step calculates the future date for which the network is to be validated.
The future date is the due date of root line item in the current order that is part of the same network, with the due date farthest in the future.
- Validate. This step invokes the Compound Product Validation Engine to validate each of the rules associated with the compound product. In case of nested validation, in addition to the current network, the compound product validation engine validates nested networks against the rules associated with the compound product. This applies only if cross-network validation is enabled.
- Violation? If cross-network validation is enabled and if there are no violations, then this step displays the following message: This compound product is valid. In case of Nested Network validation, if there are no violations and if the NestedNetworkValidated flag is set to false, which means there are no nested networks associated with the current network or that nested network validation is not invoked, then the following message appears: This compound product is valid
- NestedNetwork Validated. If there are no violations and the NestedNetworkValidated flag is set to true, which means cross-network validation is invoked, then this step displays the following message The following networks are valid: NestedNetworkname:NetworkName1,NestedNetworkname:NetworkName2.......NestedNetworkname:NetworkNameN
- Format Violation. If there are violations, then this step concatenates the error messages into a single string and displays it to the user. In case of nested network validation the error messages are concatenated with the set of valid network messages if they are found and displayed.
Table 40 shows the steps in this workflow that call business service methods.
Table 40. Associated Business Service Methods
Business Service Method Called |
Future Date |
Find Future Date |
Validate |
Validate |
Format Violation |
Format Violation |
