Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflows for Enrollment > CUT eSales - PC Prepare Cart Process WorkflowThis workflow allows the user to save the current shopping cart or to discard the cart contents before adding the product the user selects from the quotes that the price comparison process generates. Figure 50 shows this workflow. NOTE: Only customer applications use this workflow. This workflow is included in this chapter because a workflow for both employee and customer applications calls this workflow. The CUT eSales - PC Enrollment Process workflow calls this workflow as a subprocess. Workflow Description. This workflow performs the following actions:
Table 46 shows the steps in this workflow that call business service methods. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
