Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflows for Bulk Requests >
ABO Bulk Request Add Item Customize SubProcess Workflow
This workflow launches the Configurator run-time session when a user customizes a base product. Figure 68 shows this workflow. The ABO Bulk Request Add Item Customize Process workflow calls this workflow as a subprocess.
Figure 68. ABO Bulk Request Add Item Customize SubProcess Workflow
Workflow Description. This workflow performs the following actions:
- Clears the business service cache.
- Loads the current order line item into memory.
- Checks whether the action code of the root line item is Add. If the action code of the root item is not Add, then terminates the process because of an error.
- If the action code of the root line item is Add, then uses the current order line item to generate an asset.
- Stores the order header with which to associate the configured line item.
- Checks whether the port IDs for the customized instance match port IDs for the product definition.
- Launches the Configurator run-time session to reconfigure the product instance.
- Waits for the user to click a button to terminate the session.
- Gets the details of the button that the user clicks.
- Checks whether the user clicks the Cancel button.
- If the user does not click the Cancel button, then gets the configured product instance from the Configurator session.
- Stores the configured product instance.
- Creates the Delta action codes.
- Writes the order line item to the database.
- Displays the Actions applet.
Table 60 shows the steps in this workflow that call business service methods.
Table 60. Associated Business Service Methods
Reset PMT Cache |
Reset |
SIS OM PMT Service |
Load Order Line Item |
Query |
EAI Siebel Adapter |
Apply Order Line Item |
Apply |
Set Active Order Header |
Set Output Header |
Auto Match Port Ids |
AutoMatch |
Complex Product AutoMatch Service |
Reconfigure Product Instance |
Set Warning Message |
SetBusCompFields |
Shopping Service |
Get Clicked Button |
Get Cfg Button Click Information |
Get Instance |
GetInstance |
Set Product Instance (Requested) |
Set Product Instance |
Delta |
Delta |
Set Product Instance (EAI Op) |
Prepare Sync Input |
Compute EAI Operation |
Sync Order Line Item |
Synchronize |
Go To View |
GoToView |
ABO Bulk Request GoToView Service |
