Siebel Order Management Guide Addendum for Communications > Workflows for Employee Asset-Based Ordering > Workflows for Bulk Requests >
ABO Bulk Request Add Item Customize SubProcess Quotes Workflow
This workflow launches the Configurator run-time session for quotes when a user customizes a base product. Figure 90 shows this workflow. The ABO Bulk Request Add Item Customize Process Workflow workflow calls this workflow as a subprocess if the Mode value is Quote.
Figure 90. ABO Bulk Request Add Item Customize SubProcess Quotes Workflow
Workflow Description. This workflow performs the following actions:
- Reset PMT Cache. This step prevents an incomplete workflow from polluting the PMT cache.
- Load Quote Line Item. This step loads the quote line items.
- Is Action = 'Add'? This step checks whether the Action code is Add.
- Error. This step generates an error and ends the workflow.
- Apply Quote Line Item. This step applies the quote line items.
- Set Active Quote Header. This step sets the active quote header.
- Auto Match Port Ids. This step auto-matches the port Ids.
- Display Warning? This step checks whether to display any warning message.
- Set Warning Message. This step sets the warning message.
- Display Warning Message. This step displays the warning message, if any.
- Reconfigure Product Instance. This step configures again the product instance.
- Wait for Button Click. This step waits for a button click.
- Get Clicked Button. This step gets the button that the user clicked.
- Cancel Workflow? This step checks whether to cancel the workflow.
- Get Instance. This step gets the instance.
- Set Product Instance (Requested). This step sets the warning message that was requested.
- Delta. This step gets the delta.
- Set Product Instance (EAI Op). This step sets the product instance.
- Prepare Sync Input (Set EAI_OPERATION codes). This step prepares for the synchronization input.
- Sync Quote Line Item. This step synchronizes the quote line items.
- Go To View. This step goes to the view for Order, Order Lines, and Attributes.
Table 80 shows the steps in this workflow that call business service methods.
Table 80. Associated Business Service Methods
Apply Quote Line Item |
Apply |
SIS OM PMT Service |
Auto Match Port Ids |
AutoMatch |
Complex Product AutoMatch Service |
Delta |
Delta |
Get Clicked Button |
Get Cfg Button Click Information |
Get Instance |
GetInstance |
Go To View |
GoToView |
ABO Bulk Request GoToView Svc |
Load Quote Line Item |
Query |
EAI Siebel Adapter |
Prepare Sync Input (Set EAI_OPERATION codes) |
Compute EAI Operation |
Reconfigure Product Instance |
Reset PMT Cache |
Reset |
Set Active Quote Header |
Set Output Header |
Set Product Instance (EAI Op) |
Set Product Instance |
Set Product Instance (Requested) |
Set Warning Message |
SetBusCompFields |
Shopping Service |
Sync Quote Line Item |
Synchronize |
Wait for Button Click |
Sleep |
Workflow Utilities |
