Siebel Order Management Guide Addendum for Communications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites > Upgrading Bandwidth at a Network SiteTo upgrade the bandwidth at an existing network site, you must increase the speed of the network node product, for example, the port speed of the Frame Relay Port product. This task is a step in Process of Upgrading Bandwidth at Network Sites. NOTE: If you model all of your network components as simple products, instead of using this procedure and the following procedure, then you can navigate to the All Network Elements view of the Networks screen and select both the Network Node and the Network Connection that you want to upgrade. After you select the two or more items, click Modify and a new change quote appears with all selected items as line items. Then navigate to the Attributes view tab and upgrade accordingly. To upgrade bandwidth at a network site
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
