Siebel Order Management Guide Addendum for Communications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites > Upgrading Bandwidth of a Network ConnectionTo upgrade the Committed Information Rate (CIR) on a network connection, you use the change quote that appears after the last step in Upgrading Bandwidth at a Network Site. This task is a step in Process of Upgrading Bandwidth at Network Sites. To upgrade the bandwidth of a network connection
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
