Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > User Property Reference for Cross-Network Validation >
ValidateOtherNetwork
The ValidateOtherNetwork user property allows you to enable and disable cross-network validation. Table 141 describes the ValidateOtherNetwork user property.
Table 141. ValidateOtherNetwork User Property
Value |
Y or N |
Usage |
To enable cross-network validation, set the ValidateOtherNetwork user property value to Y. To disable this feature, set the value to N. |
Parent Object Type |
Business Service |
Functional Area |
VORD CPVE Validation Service |
