Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > User Property Reference for Cross-Network Validation > VORDConnectionToNodeSearchSpecThe VORDConnectionToNodeSearchSpec user property allows you to configure a search specification for use with cascade deletion. That is, if you disconnect a network node, then the corresponding network connection is disconnected. Table 144 describes the VORDConnectionToNodeSearchSpec user property. |
Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
