Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > Process of Defining Compound Products for a Network > Defining Products for the NetworkYou must define all the network elements, including the network product and the network components, as products. This task is a step in Process of Defining Compound Products for a Network. Defining the Network ProductYou can define the network product for network ordering (for example, the frame relay) in the same way that you define other customizable products using the Customizable Products view of the Administration - Products screen, but you must enter information in additional fields. Configurator rules are not required but you can use these rules if needed. For more information about defining customizable products, see Siebel Product Administration Guide.
Defining Network Components as ProductsWhen customers order networks, salespeople add nodes and connections (for example, ports and PVCs) to the network. You must set up each of these products using Administration - Products screen, Customizable Products view, Product Designer and Rule Designer subviews to make sure that salespeople select only valid combinations of features for each node and connection. To allow the salesperson to add these components to the network, you must:
For more information about creating products and configuration rules, see Siebel Product Administration Guide. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
