Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > Process of Defining Compound Products for a NetworkA network is a compound product or a loose group of products that a common key ties together. The following component types make up the compound product structure:
Each of these network product components is a self-contained product that can be a customizable product, so users can configure each component of the network separately using Oracle's Siebel Configurator. The compound product structure facilitates validation across all the individual products (cross-element validation). To define a network as products, perform the following tasks:
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
