Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > Process of Defining Compound Products for a Network > Defining Maximum and Minimum Quantities for Network ComponentsThe Component Cardinality Checker business service allows product administrators to specify the maximum and minimum quantities of the network product and of the network components. This task is a step in Process of Defining Compound Products for a Network. To define maximum and minimum quantities for network components
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
