Siebel Order Management Guide Addendum for Communications > Workflows for Partner Asset-Based Ordering > CUT eChannel - Goto Product Catalog View WorkflowIf the user is identified as a Standard Partner Commerce user, then this workflow displays the product catalog for Standard Partner Commerce. The user can browse eCatalog, select products, and add products to the shopping cart. Figure 169 shows this workflow. The CUT eChannel - New Products & Services Process workflow calls this workflow as a subprocess. Workflow Description. This workflow performs the following action:
Related Topics |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
