Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups > Process of Managing Promotion Group Members >
Viewing Membership Information for an Asset
You can display membership information for any member asset of a promotion group. This task is a step in Process of Managing Promotion Group Members. To view membership information for an asset
- Navigate to the Accounts screen, then the Accounts List view.
- In the Accounts List, find the account associated with the asset for which you want to view the promotion group membership information, and click the link in the Account Name field.
- Click the Installed Assets view tab.
- In the Installed Assets list, select the promotion group member asset for which you want to view membership information.
If the Promotion Group Member field check box for an asset record is selected, then the asset is a member of at least one promotion group.
- In the Installed Assets link bar near the bottom of the view, click the Attributes link.
The Attributes list displays all the dynamic attributes for the selected member.
- In the Installed Assets link bar near the bottom of the view, click the Memberships link.
The Memberships list displays all the memberships of the selected promotion group member asset. The action buttons in the view are disabled or enabled, depending on the access control rules of the promotion group and the account context of the caller. For more information about access control, see Promotion Group Access Control Reference.
