Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups >
Promotion Group Access Control Reference
To control who is entitled to add members to or remove members from a promotion group, product administrators create access control rules when setting up the promotion group definition. Your Siebel application enforces these rules when call center agents add members to or remove members from promotion groups. Member access right values are summarized in Table 111.
Table 111. Member Access Right Values
Defines the Ability to... |
Manage Members |
Add, disconnect, and modify members in the entire promotion group. |
Manage Self |
Disconnect and modify one's own membership. Does not include the ability to add oneself to the membership. |
Add Self |
Add oneself to the membership. |
Modify Self |
Modify one's own membership. |
View Members |
View the promotion group members. |
Disconnect Self |
Disconnect oneself from the membership. |
At run time, by default, only promotion group owners can manage the memberships. In addition, your Siebel application enforces access control rules as follows:
- The owner, billing, and service accounts of the promotion group have full access rights to the entire promotion group.
- The owner, billing, and service accounts of an asset associated with a membership that has the Manage Members access right have full access rights to the entire promotion group.
- The owner, billing, and service accounts of an asset associated with a membership that has the Manage Self access right can modify and disconnect that membership. However, these accounts cannot perform these actions on other memberships in the promotion group.
- The owner, billing, and service accounts of an asset associated with a membership that has the Modify Self access right can modify that membership.
- A customer can subscribe to the membership of a promotion group if one of the following statements is true:
- The customer is the holder of the owner, billing, or service account of the promotion group.
- The customer is the holder of the Owner, Billing, or Service Account of an asset already associated with a membership of that promotion group, with the Manage Members access right.
- The membership has the Add Self access right.
- The owner, billing, and service accounts of an asset associated with a membership that has the View Members access right can see all members of the promotion group.
The enforcement of access control rules affects the Promotion Groups screen, Restricted Components view and the Accounts screen, Installed Assets view, as described in the topics that follow. Access Control Rules and the Restricted Components View
In the Promotion Groups screen, Restricted Components view, the access control rules affect the contents of the Components list, the Modify and Disconnect buttons of the Components list, and the Add button of the Promotion Group Definition list. Components list contents. The Components list displays all membership and reward products of the promotion group only in the following cases:
- The account context is the owner, billing, or service account of the promotion group.
- The account context is the owner, billing, or service account of an asset associated with a membership of the promotion group that has the Manage Members access right.
- The account context is the owner, billing, or service account of an asset associated with a membership of the promotion group that has the View Members access right.
Components list menu options. If the account context is the owner, billing, or service account of the promotion group or of an asset associated with a membership that has the Manage Members access right, then the options are enabled regardless of which list row is selected. If these conditions do not apply, then the state of each option depends on the access rights of the selected row, as follows:
- If the account context of the selected row is the owner, billing, or service account of an asset associated with the selected membership and the membership has the Manage Self access right, then all options are enabled.
- If the account context of the selected row is the owner, billing, or service account of an asset associated with the selected membership and the membership has the Modify Self access right, then the Modify option is enabled.
Promotion Group Definition Add button. If the account context is the owner, billing, or service account of the promotion group or of an asset associated with a membership that has the Manage Members access right, then the Add button is enabled regardless of which list row is selected. If these conditions do not apply, then the Add button is enabled only if the selected membership has the Add Self access right. These facts have the following consequences:
The effects of access control rules on this view are summarized in Table 112, where the cell contents signify the following meanings:
- All. All components of a promotion group are displayed.
- Account. Only the promotion group components that belong to the current account context are displayed.
- Enabled. The object is enabled.
- Disabled. The object is disabled.
Table 112. Access Control Rules and the Restricted Components View
Promotion Group Owner |
All |
Enabled |
Enabled |
Enabled |
Manage Members |
All |
Enabled |
Enabled |
Enabled |
Manage Self |
Account |
Enabled |
Enabled |
Disabled |
Disconnect Self |
Account |
Disabled |
Enabled |
Disabled |
Modify Self |
Account |
Enabled |
Disabled |
Disabled |
Add Self |
Account |
Disabled |
Disabled |
Enabled |
View Members |
All |
Disabled |
Disabled |
Disabled |
Access Control Rules and the Installed Assets View
In the Accounts screen, Installed Assets view, whether the Modify and Disconnect buttons are enabled or disabled varies according to the access rights of the selected membership row. The effects of access control rules on this view are summarized in Table 113, where the cell contents signify the following meanings:
- Enabled. The option is enabled.
- Disabled. The option is disabled.
Table 113. Access Control Rules and the Memberships Subview
Enabled |
Enabled |
Manage Members |
Enabled |
Enabled |
Manage Self |
Enabled |
Enabled |
Disconnect Self |
Disabled |
Enabled |
Modify Self |
Enabled |
Disabled |
Add Self |
Disabled |
Disabled |
View Members |
Disabled |
Disabled |
