Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups >
Promotion Group Disconnect Reference
This topic describes the internal processes that occur in your Siebel application when promotion groups and their components are disconnected. This topic covers the following subjects:
NOTE: A promotion associated with a promotion group membership cannot be split or merged.
When a promotion group is disconnected, your Siebel application performs the following steps and validations:
- If a promotion group commitment is broken, then your Siebel application calculates the penalty charge for the promotion group.
- For each membership,
- If the Delete Member Asset flag is set to Yes:
- If the asset is associated with other memberships, then it stops the process and displays a message saying that the asset must be disconnected first.
- Otherwise, if the asset is a bundled promotion, and if its commitment is broken, then it calculates the bundled promotion penalty charge.
- If a membership commitment is broken, then it calculates the membership penalty charges.
- If a commitment has been broken in Step 1 or Step 2, then it displays a warning message.
- If the user confirms the disconnect action, then it does the following:
- Creates a new order.
- Adds the promotion group and its memberships and rewards as line items, each with an Action Code of Delete.
- For each membership, it does the following:
- If the Delete Member Asset flag is set to Yes, then it adds the member as a line item with an Action Code of Delete.
- Otherwise, if the Validate Member Asset flag is set to Yes, then it adds the member as a line item. If a pricing adjustment is defined for the member asset, then the line item has an Action Code of Update.
- Adds the rolled-up penalty charges with an Action Code of Add.
Membership Disconnect
When a promotion group membership is disconnected, your Siebel application performs the following steps and validations:
- If a membership commitment is broken, then your Siebel application calculates the penalty charge.
- If the user confirms the disconnect action, then:
- Adds the membership as line item with an Action Code of Delete.
- Otherwise, the if Validate Member Asset flag is set to Yes, then it adds the member as a line item. If a pricing adjustment is defined for the member asset, then the line item has an Action Code of Update.
Membership Asset Disconnect
When an asset associated with a promotion group membership is disconnected, then your Siebel application performs the following steps and validations:
- If the asset is a bundled promotion and its commitment is broken, then your Siebel application calculates the penalty charge.
- For each associated membership, if a commitment is broken, then it calculates the penalty charge.
- Adds the asset as a line item with an Action Code of Delete.
- If the asset is a bundled promotion, then it adds its components with an Action Code of Delete or Update, depending on how the bundled promotion is set up.
- For each associated membership, it adds the membership as a line item with an Action Code of Delete.
- Adds all the rolled-up penalty charges with an Action Code of Add.
- If cardinality is violated, then it displays a warning message about a cardinality violation.
