Siebel Order Management Guide Addendum for Communications > Workflows for Promotion Groups > Workflows That Process Agreements > Configurator Product Info Lookup WorkflowThis workflow queries non-versioned product information, which is used for internal instance loading. A document in the context of order management can be a quote, order, asset, or agreement. Internally the documents are converted into property sets that can be updated, added, removed, or merged. The workflow takes agreement documents into one path from the other three document types into another path. This is because some fields that exist in quotes, orders, and assets do not exist in agreements. This workflow is called from the Cfg Product Info signal, which is generated internally when a customizable product is added. Figure 157 illustrates this workflow. Workflow Description. This workflow performs the following actions:
Table 126 describes the steps in this workflow that call a business service method. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
