Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods >
Copy Method
The method copies the source instance to the destination instance based on the defined copy map.
Arguments
Argument
Description
SourceInstance
[in] Source instance name.
DestinationInstance
[in] Destination instance name.
MapName
[in] Data map name.
CachedUpdate
[in] Y or N. Performance option to allow for cached updates. All SQL generated in the operation is issued to the database in one batch. Therefore, a SQL in the block cannot depend on a previous SQL being committed to the database. (Optional)
Release
[in] Source, Destination, or All. If defined, the corresponding instance(s) is popped up and released after the operation. (Optional)
Siebel Order Management Infrastructure Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
