Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Credit Check Service >
CreditCheckRunCheck Method
This method runs a credit check for the selected order or quote from an external ASI source, then writes the credit status to the database.
Arguments
Argument
Description
Id
[in] The ID of the quote or order.
Inbound Integration Object
[in] The internal inbound integration object for Quote or Order.
Outbound Integration Object
[in] The internal outbound integration object for Quote or Order.
Return Error
[in] A flag for which, when set to "N", the function will return an OK regardless. (This is used for situations in which even if the credit check errors out, you want to create the order.)
Siebel Order Management Infrastructure Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
