Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Disable Service >
DisableCheckCanInsert Method
This method skips the CanInsert check on the business component when new records are inserted. Arguments
EnableCanInsert |
[in] Y or N. When Y, the business component will skip the CanInsert check. |
InstanceName |
[in] ISS business component instance name. |
BusCompName |
[in] Name of the business component inside the ISS instance business object. The BusComp class must be derived from CSSBCOrderMgmtBase. |
