SiebelMessage |
[in] Contains a single complex Open Order line item. |
Account Id |
[out] Row ID of the Account associated to the Order. |
Asset Integration Id |
[out] Asset integration ID that is used to open order items for an asset. |
Contact Id |
[out] Row ID of the Contact associated with the Order. |
Old Promotion Id |
[out] Row ID of the existing Promotion that is already an Asset. This is set in the SetOldAssetDetails method. This argument is used in the case of a Promotion Upgrade. |
Old Promotion Instance Id |
[out] Promotion Instance Integration ID of the old promotion that is already an asset. This is set in the SetOldAssetDetails method. This argument is used in the case of a Promotion Upgrade. |
Product Type |
[out] Type of the Root Product on the line item. For example, Product or Promotion. |
Promotion Id |
[out] Row ID of the Promotion associated with the line item. |
[out] Promotion Instance Integration ID of the line item. This indicates the promotion instance with which the line item is associated. |
Promotion Rule Id |
[out] Row ID of the promotion component rule that this line item references. |
Promotion Source Instance Id |
[out] Promotion Instance Upgrade Integration ID on the line item. This is relevant only in the case of a promotion upgrade. |
Root Product Id |
[out] Row ID of the root product or promotion. |
Root Product Name |
[out] Name of the root product or promotion. |
Status |
[out] Promotion Status returned by this method. This argument is used in workflows for branching. |
