Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Promotion Edit UI Service >
EditPromotion Method
This method is an entry function to enter a Promotion Edit UI session. NOTE: The product type for the selected record must be set to Promotion.
Arguments
Promotion Def |
[in] The Promotion Def Id of the selected promotion record. |
Promotion Instance |
[in] The Promotion Instance Id of the selected promotion record. |
Return View |
[in] Returns the view name when the user completes an Edit UI session. |
