| Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS ATP Service > CSSISSFulfillmentService::ATPRunCheck Method
 This method provides a business service wrapper function for ATP ASIs. Arguments
    | Id | [in] The header ID for the quote or order. |
    | Line Item Id | [in] If "inquire at line level" is called, this contains the line ID. If "inquire all" is called, then this is empty. |
    | Inbound Integration Object | [in] The inbound internal integration object must be quote-specific or order-specific. This is used for database write. |
    | Outbound Integration Object | [in] The outbound internal integration object must be quote-specific or order-specific. This is used for database query. |
    | ATPAction | [in] The action to be specified at the line level: such as Inquire, Reserve, and so on. |
 Example Arguments["ATP Action"] = "Inquire";["Outbound Integration Object"] = "ATP Check Interface Request - Orders";
 ["Inbound Integration Object"] = "ATP Check Interface Response - Orders";
 ["Id"] = "99-2AICU";
 ["Line Item Id"] = "42-4ZBY1";
 ["Outbound Integration Object1"] = "ATP Check Interface Request - Orders";
 ["Inbound Integration Object1"] = "ATP Check Interface Response - Orders";
