Siebel Order Management Infrastructure Guide > PSP Engine > Configuring PSP Procedures > Creating PSP ProceduresPSP procedures are created in the same way that standard workflow processes are created. For information about creating workflow processes, see Siebel Business Process Framework: Workflow Guide.
CAUTION: PSP requires that each input property set for a PSP procedure step must also be defined as an output property set, even though the input property set is technically not output. This is required by a workflow performance optimization that makes sure input and output property sets are not copied when the transform method is invoked. |
Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
