Siebel Order Management Infrastructure Guide > Variable Maps > About Using Variable Maps > Using the Instance Source Type for the Customizable Product Instance Property SetsIf you are working with customizable product instance property sets, use the Instance source type. The Instance source type retrieves data from the business component initiating the signal that causes the GetRowSetData method to be called. Data can also be retrieved from any parent or child business component. To define the data element to be retrieved
Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
