Siebel Order Management Infrastructure Guide > Variable Maps > Components of Variable Maps > Configuring ISS Integration ObjectsIntegration object configuration is used to create uniform field names for different physical business components (such as Quote Item, Order Item, and so on). When defining variable maps then, you can specify one source path for all modes. NOTE: To avoid errors when trying to retrieve data from business components, it is recommended that you always define the component field names in integration objects, and use the uniform name in the variable source path for necessary modes only. At run time, the user property of the business component that raised the signal determines which integration object to use. For each business component, there are various user properties (such as the property called Instance Uniform Name EAI Object:Catalog). To configure ISS integration objects
| Siebel Order Management Infrastructure Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
