Siebel Personalization Administration Guide > Targeting Content by Using Expressions > About Creating Rule Sets and Rules >
Creating a New Rule
This procedure describes the process of creating a new rule.
To create a new rule
  1. Navigate to the Administration - Personalization screen > Rule Sets view.
  2. Select a rule set.
  3. In the Rules list, create a new record.
    Complete the fields as needed. Some fields are described in the following table.
    Field
    Description
    Sequence
    Required. Enter numbers in this field to set the rules evaluation order. Evaluation begins with the rule with the lowest sequence number and continues until all rules are evaluated, except that -1 is evaluated last.
    Rules with the same sequence number are evaluated in random order.
    The sequence number for rules does not have the same significance as for rule sets, because all the rules in a rule set are evaluated whether content is returned or not.
    Rule sequence is very important, however, for the order of the text strings displayed in salutation applets.
    Rule Type
    Select a rule type from the drop-down menu:
    • Expressions. Evaluates inclusion and exclusion expressions directly.
    • BusService. Invokes a business service and expects a property set in return, which is passed on to the business component.
      The input argument to Business Service is a property set with four properties: Context, BusComp, RuleSet, and Rule.
    • Invoke Method. Invokes a method on the business component to get a string, which is the search specification.
      The input argument to Invoke Method is a string.
    Active
    Check the box to use the rule.
    Conditional Expression
    Optional. Use the conditional expression to control the evaluation of the rule, or to set up Boolean logic for evaluation of all the rules in the rule set.
    Include Expression
    Use with the Expressions rule type. An expression that sets parameters to include content.
    Exclude Expression
    Use with the Expressions rule type. An expression that sets parameters to exclude content.
    Business Service Name
    Name of the business service to invoke, if the conditional expression evaluates to TRUE and the rule type is BusService.
    Business Service Method
    Method to invoke on the business service.
    Business Service Context
    Parameter to pass to the business service method. While a business service can take many name/value pair parameters, you can only pass one parameter—called Context—in Siebel Personalization.
    An example of a business service context is
    UserType=Partner;AccountState=Gold
    Method Name
    Method to invoke on the business component, if the conditional expression associated with the rule evaluates to TRUE and the rule type is Invoke Method.
    Method Argument
    Parameter to pass the business component. You can only pass one argument.
Siebel Personalization Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
