Siebel Personalization Administration Guide > Targeting Content by Using Expressions >
Associating Rule Sets With Applets
This procedure describes how to use the Rule Sets list to associate existing rule sets with applets.
For information on creating rule sets, see About Creating Rule Sets and Rules.
To associate rule sets with an applet
  1. Navigate to the Administration - Personalization screen > Applets view.
  2. Select an applet.
  3. Scroll down to the Rules Sets list, and create a new record.
  4. In the Name field, select a rule set.
    Complete the fields as needed. Some fields are described in the following table.
    Field
    Description
    Sequence
    Choose the order in which to evaluate the rule sets.
    Start Date
    The date after which the conditional expression is evaluated.
    If Start Date is blank, the conditional expression is evaluated continuously or until the End Date is reached.
    End Date
    The date after which the conditional expression is not evaluated.
    If End Date is blank, the conditional expression is evaluated continuously after the Start Date. If both Start and End Date are blank, the conditional expression is always evaluated.
    Conditional Expression
    Processes the rule set if the expression evaluates to TRUE.
Siebel Personalization Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
