Siebel Pricing Administration Guide > Siebel Pricer Deployment and Integration > Workflows for External Pricing API >
Get Config Item Price Workflow
The GetConfigItemPrice Business Service Method is an API that fetches price adjustments from Customizable Product Pricing Designer for a price list, product, or product port combination. Figure 52 illustrates the GetConfigItemPrice workflow process.
Figure 52. GetConfigItemPrice Workflow Process
Workflow Description. This workflow does the following:
  1. Get List Price. Gets the List Price for the input product and price list, which provides the basis for subsequent Pricing Designer adjustments.
  2. Get Root Price List Item Id and Customizable Product Adjustment. These steps retrieve the Customizable Product Pricing Designer adjustment.
Table 90 lists the steps in the GetConfigItemPrice workflow with the business service and method that is called by each.
Table 90. Steps of the GetConfigItemPrice Workflow
Name
Type
Business Service
Method
Sub Process
Description
Get List Price
Business Service
Row Set Transformation Toolkit Service
Simple Look-Up Transform
Not applicable
Gets the List Price for the input product and price list.
Business Service
Not applicable
Retrieves the Root Price List Item Id for each item for use in the next step.
Business Service
Not applicable
Queries in Price Config Item Buscomp for Pricing Designer adjustments.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
