Siebel Pricing Administration Guide > Siebel Pricer Deployment and Integration > Internal Integration of Siebel Pricer >
Triggering CalculatePriceForOpportunity
Use the following procedure to expose a button on the UI to trigger CalculatePriceForOpportunity.
To expose a button on the UI to trigger CalculatePriceForOpportunity
  1. Alter the Opportunity Product applet as follows:
    1. In the Object Explorer applet, drill down on Siebel Objects and Applet.
    2. In Applets, input the following:
      <New Query>
      Name = Opportunity Product Applet
      <Execute Query>
      Lock the project.
  2. Add Controls <Reprice>
    1. In the Object Explorer applet, click Control.
    2. In the Controls applet, input the following:
      <New Record>
      Name = Reprice
      Caption = Reprice
      HTML Type = MiniButton
      Method Invoked = CalculatePriceForOpportunity
  3. Display the Web template:
    1. In the Object Explorer applet, click Applet Web Template.
    2. In Applet Web Templates, input the following:
      Select Name = Edit List
      Menu: View, Editors, Web Applet Editor
  4. Add controls to the template as follows:
    1. Navigate to the Controls or Columns applet at the bottom left of the screen.
    2. Select Reprice, and then drag and drop to [x] next to last labeled control [Edit].
      Create a button on the UI to raise a signal.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
