Siebel Pricing Administration Guide > Siebel Pricer Deployment and Integration > Internal Integration of Siebel PricerWithout configuration, pricing functionality is used by quotes, orders, and agreements. You can configure the application so that any business component can use pricing functionality. This topic gives an example of configuring the Opportunity business component to integrate it with Pricer. You can use similar methods for other business components. This example allows the Opportunity and Opportunity Product business components to invoke the pricing procedure. For information about the pricing procedure, see Siebel Pricer Technical Reference. CAUTION: Perform these changes on the local environment only. The change has enterprise-wide effect and may affect others using the same URL. Do not perform these changes unless you are familiar with Siebel Tools and Siebel order management infrastructure. To allow the Opportunity and Opportunity Product business components to invoke the pricing procedure, do the following:
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
