Siebel Pricing Administration Guide > Siebel Pricer Deployment and Integration > Internal Integration of Siebel Pricer >
Creating an Integration Object
Use the following procedure to create an Integration Object.
To create an integration object
  1. Create a new record, ISS Opportunity Integration Object, as shown in the following table:
    Name
    Project
    Business Object
    External Name
    XML Tag
    ISS Opportunity
    ISS Order Management
    Opportunity
    ISS Object
    ListOfISSObject
  2. Create a new record, ISS Opportunity Integration Object, as shown in the following table:
    Name
    External Name Context
    Parent Integration Component
    External Name
    External Sequence
    Card-inality
    XML Container Elemen
    XML Tag
    Header
    Opportunity
    Opportunity
    1
    One
    ListOfHeader
    Header
    Line Item
    Opportunity Product
    Header
    Opportunity Product
    2
    Zero or More
    ListOfLineItem
    LineItem
  3. Enter Integration Component Fields of Opportunity, as shown in the following table:
    Name
    Data Type
    Length
    External Name
    External Data Type
    External Length
    XML Style
    XML Tag
    Name
    DTYPE_TEXT
    50
    Name
    DTYPE_TEXT
    50
    Element
    Name
  4. Enter Integration Component Fields of Opportunity Product, as shown in the following table:
    Name
    Data Type
    Length
    Precision
    External Name
    External Data Type
    External Length
    XML Style
    XML Tag
    Comment
    DTYPE_TEXT
    255
    N/A
    Comment
    DTYPE_TEXT
    255
    Element
    Comment
    Cost
    DTYPE_NUMBER
    N/A
    N/A
    Cost
    DTYPE_NUMBER
    N/A
    Element
    Cost
    Product Id
    DTYPE_ID
    N/A
    N/A
    Product Id
    DTYPE_ID
    N/A
    Element
    ProductId
    Product Price
    DTYPE_NUMBER
    N/A
    N/A
    Product Price
    DTYPE_NUMBER
    N/A
    Element
    ProductPrice
    Product Quantity
    DTYPE_NUMBER
    N/A
    16
    Product Quantity
    DTYPE_NUMBER
    N/A
    Element
    Product Quantity
    Quotable
    DTYPE_TEXT
    N/A
    N/A
    Quotable
    DTYPE_BOOL
    N/A
    Element
    Quotable
    Revenue
    DTYPE_NUMBER
    N/A
    N/A
    Revenue
    DTYPE_NUMBER
    N/A
    Element
    Revenue
    Create the uniform field map used by the variable map.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
