Siebel Pricing Administration Guide > Siebel Pricer Deployment and Integration > Internal Integration of Siebel Pricer >
Creating the Variable Map
Use the following procedure to create the variable map.
To create the variable map
  1. Create the Opportunity Pricing Variable Map - Context Variable Map.
  2. Drill down on Workspace.
  3. Create the Variable Definition as shown in the following table:
    Variable Name
    In/Out
    Type
    On Null
    Name
    In/Out
    Text
    Ignore
  4. Create the Variable Source for the Variable Definition as shown in the following table:
    Mode
    Path
    Source Type
    Opportunity
    $Current/Header/Name
    Instance
  5. Click the Mode tab and create the recording as shown in the following table:
    Mode
    Object Name
    Any
    Header
  6. Create the Opportunity Pricing Variable Map - Row Set Variable Map.
  7. Drill down on Workspace.
  8. Create the Variable Definitions as shown in the following table:
    Variable Name
    In/Out
    Type
    On Null
    Comment
    In/Out
    Text
    Ignore
    Cost
    In/Out
    Number
    Ignore
    Product Id
    In/Out
    Id
    Ignore
    Product Price
    In/Out
    Number
    Ignore
    Product Quantity
    In/Out
    Number
    Ignore
    Quotable
    In/Out
    Boolean
    Ignore
    Revenue
    In/Out
    Number
    Ignore
  9. Create the Variable Source for each of these Variable Definitions as shown in the following table
    Mode
    Path
    Source Type
    Opportunity
    $Current/Line Item/Comment
    Instance
    Opportunity
    $Current/Line Item/Cost
    Instance
    Opportunity
    $Current/Line Item/Product Id
    Instance
    Opportunity
    $Current/Line Item/Product Price
    Instance
    Opportunity
    $Current/Line Item/Product Quantity
    Instance
    Opportunity
    $Current/Line Item/Quotable
    Instance
    Opportunity
    $Current/Line Item/Revenue
    Instance
  10. Click the Mode tab and create the recording as shown in the following table:
    Mode
    Object Name
    Any
    Line Item
    Create the variable maps referenced by the signal.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
