Siebel Pricing Administration Guide > Creating and Assigning Rate Lists > Process of Creating Rate Lists > Creating Rate List Line ItemsThis task is a step in Process of Creating Rate Lists. A rate list line item contains rate data for a specific resource. It includes the resource name and information about the rates charged for that resource. If you have multiple rate lists, then the same resource can have a line item in each rate list. For example, your United States rate list might have a line item for the rate charged for a resource in the United States. The Canadian rate list may have the rate charged for the resource in Canada, and so on. Alternatively, you can add a resource to multiple rate lists using the Administration - Product screen, then Rate List view. NOTE: Because rate list line items do not have fields for their start and end dates, you cannot have more than one line item for a given resource. To create a rate list line item
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
